"I have a 1984 ski supreme wit
"I have a 1984 ski supreme with a 351 Ford. The alternator is putting out 14.5 volts, but at the battery I am getting only 11.9-11.95, no more. I have the small wire, not the big black or red wire, hooked up to the negative side of the battery and almost all gages are working. Should that small wire be on the positive side? How does the electricity from the alternator get from the alternator to the battery? What is the PATH. Does the little wire go to the negative side of the battery??? Is it possible I have a bad regulator. Where is it located. thank you, keith"
