captain_ed
I have a 1977 Jersey Dawn with twin 440 chrysler inboards and a westerbeke 8kw generator. The generator has its own battery as does each 440 inboard. There is a set of wires tapped off of the port side 440 starting battery that feeds the electric panel on the flybridge.
I have something draining the batteries down if not plugged into the dock current that feeds the 3 bank charger. I think the power draw from the bridge is the culprit.
Both starting batteries for the main engines will drain down in a week or two. Batteries are new. The old batteries did the same thing.
I am wondering why both batteries would drain and not just the port battery that also feeds the bridge? Someone has added a ground cable (thick battery cable) between the two exhaust manifolds of the two main engines. Would this or could this cause the starboard battery to draw down along with the port battery? There is also a battery ground cable going from each starting battery negative to each engine manifold for grounds. I am not sure why the two engines would be tied together by the extra cable? Is this normal/or acceptable practice?
Thanks for any help!
