hi all .heres my qustion. first off i run 2 batteryies on my boat. i run a 60 hp 1970 johnson. i have been told to allways have a good charged battery or i will cause damage to the amp and other ele parts.i ran parellel thick gauge wire from positive to pos and neg to neg . before i did this i just had the 2. one just to start motor and one to run lights radio fish finder bildge pump.this way i all ways had a good charged bat when starting. well the batt for all the extras would die out on me . so i hooked them up in the parellel .figureing i can charge the other one with the motor.how does this work do i get double the life when the motor is off. and does this cause my charging system to work over time.i think i need to hook up a volt gauge so when the motor is not running and i am using the extras and drawing power i will no when to start up and charge. does all this make sence . now hear is my other qustion i want to run my 40 thrust troller ele motor useing a third battery after a while of trolling the batt will die out. can i jump a other temp parrelel line to boost a third trolling motor. or is all this silly. what do you all say
