"This is not about crusaders b
"This is not about crusaders but this is a well versed group so I'm hoping for some guidance. I'm changing house batteries on my boat and increasing from two 6 volt to four 6 volt, and adding an inverter. I will be using 2/0 cable for the inverter (what the manufacture calls for). My question is this, should the inverter cables be the same length (pos/neg)the set up will allow for a 3 ft negative and a 4 ft positive, but I was wondering if they should be the same length. Next question is for the cables between the batteries for the series and parallel concections. What size should I use?
Thanks in advance for the help"
