mcw
Hi all
Can anyone help as to the best or correct way in checking the trim leg angle against the trim leg digital gauge, I have the manual on the V/P 290 leg and it tells you to lower the leg fully down, then add 20lbs of weight to the leg and adjust the trim sender show it shows -3 to -4 on the dash gauge depending on what your angle of transom is.
I have no idea what my transom angle is on a 1994 wellcraft 20 excell cuddy, is there any other way of setting up so i can check that the leg is showing the correct angle on the helm gauge
markw
markw
