whaler_warner
Probably the wrong place to post this, however i have recently picked up a used but good condition Michigan Wheel Ballistic stainless steel prop for my M90A.
The current set up is a non OEM aluminium prop and the thrust washer for this prop doesnt fit the Ballistic.
Is anyone able to confirm if the Tohatsu original thrust washer (3B7-64231-1) will fit the ballistic prop? they are quite expensive and my local Tohatsu dealer wont order one to let me check fitment first.
Just to add this is the older style Ballistic which has a rubber hub and not the later changeable hub, I have contacted the UK distributor for Ballistic and they only have the kit for the later style units but again thought the OEM thrust washer should fit.
