First time post here, so here goes:
I got an 1988 5.0 (305 chevy) with a coil/alternator ballast resistor I managed to mangle. The ignition is a stock points Prestolite Marine distributer. From reading up on voltage drop and all that good stuff, it seems I should get a 0.7ohm replacement, (Figuring dropping the voltage from 12 to 8 volts or so also maybe 4 or 5 amps to power the coil) , but resistor in question actually read 70 ohms on a meter. Wondering how I could be so far off on a fairly simple calculation?
Or maybe there is a sight were I could locate the exact replacement part? Thanks
