"Here's the background: 4
"Here's the background: 454/330hp mercruiser alpha1. After long layup, (2 years) I brought it out this summer. With a new battery, it started right up, but ran very rough with a misfire. As the gas smelled bad, I drained the tank, changed the fuel filter, no change. Carb rebuilt. No change. I found oil leaking from coil, so went ahead with full tune up parts including coil, plugs, wires, cap, rotor, and ignition sensor. I could then get it to run smooth at times, thought I might have had a shift interuptswitch problem,as I could wiggle the inturpt shift and get it to run fine sometimes. I found a bad shift cable bellows, so changed cable and bellows. Now I cannot get it to routinely run smooth even with the shift interupt disconnected. It is a very rythmic misfire, it runs smooth sometimes, just not all the time.
Any thoughts? Could the Thunderbolt IV (I think) be inconsistent in producing an amplified spark. I put a timing light on it last night, and at times get a consistent pulse/light, but at other times seem to get a double firing of the timing light. Seems odd. I have went over wiring looking for perhaps a chaffed or pinched harness, possibly grounding out, but so far have found none."
