redrightreturn
Just bought this boat last week and ran it fairly successfully the first few hours. Was running great at an idle and 3/4 throttle but would occasionally misfire at full throttle. A few times it died at full throttle almost like someone hit the kill switch. When it did die it would start up again within a minute and run perfectly normal. A few days later I took it out again and it started perfectly and ran fine at idle and low speed. Couldn't even get it opened up without misfiring this time. Misfired maybe 3 times and then shut down completely after about 3 minutes of running. Finally started again after 10 minutes of cranking and got it opened up to half throttle and died again. Now can't get it started again.
I'm getting fuel no problem but not getting any spark now. Engine cranks strong. I'm thinking the powerpack which I don't mind replacing since even if it isn't bad it would be a good idea to have a spare with the age of the motor (350 hours).
