hystat
Outstanding Contributor
A few years ago, I traded about $50 worth of OMC parts for an AQ130C engine at a marine outdrive rebuild place. The guy knew nothing about the motor. he had collected the engine with an outdrive.
I just recently got around to looking at it (had the starter off my 131's B18 anyhow, so thought I would use it to do a comp test/evaluation of this B20 now)
My thoughts so far: looks like a fresh but poor rebuild recently done....an abrupt oil pump failure made the p.o. give up on it.
The oil pump shaft is splayed open and it broke and bent the distributor shaft from the load. Oddly I don't see any debris locking the pump, but some telling wear on the gears - says misalignment- corner loading and contact fatigue of the pump gear teeth... it was not a good pump.
I pulled the rod bearing caps.... almost look like new bearings- notice the rebuilder's finger print on the #1 rod cap
I suppose the FBI could help me find him...haha
talk about signing your work
![smile.png](http://forums.swedespeed.com/images/smilies/smile.png)
![aq130c008.jpg](http://i5.photobucket.com/albums/y184/hystat/aq130c%20b20/aq130c008.jpg)
![aq130c012.jpg](http://i5.photobucket.com/albums/y184/hystat/aq130c%20b20/aq130c012.jpg)
![aq130c010.jpg](http://i5.photobucket.com/albums/y184/hystat/aq130c%20b20/aq130c010.jpg)
![aq130c013.jpg](http://i5.photobucket.com/albums/y184/hystat/aq130c%20b20/aq130c013.jpg)
![aq130c002.jpg](http://i5.photobucket.com/albums/y184/hystat/aq130c%20b20/aq130c002.jpg)
