Bad Idle No Power
garsha
"It's power likes 5Hp engi
"It's power likes 5Hp engine, bad idle.
But removed fuel line connector from fuel tank,
it's good condition after 10 second till spend
all fuel in the engine.
So clened caburaetor, didn't help."
"Remove carb. Clean thoroughly
"Remove carb. Clean thoroughly. Replace all gaskets, needle, etc.. Set float at correct height and reassemble.
Jeff"
"Rebuild" starts with
"Rebuild" starts with getting a manual or taking it to a dealer. Going rate for a single carb rebuild is about 200-250 bucks depending on the cost of the kit...
Outboards are expensive toys...
