brian_from_boston
"Another coin flip. 1988 29 B
"Another coin flip. 1988 29 Blackfin twin 454 crusaders. Boat has 1 main tank and two saddle tanks. All aluminum. I have used only the main tank this year. last year my season ended early before I could even use my saddle tanks. So Saddle tank fuel is atlest 1-2 years old. It was stabilized and I put 2 cans of Sea Foam in each before a 3-4 hour run a few weeks ago. (2 cans of Sea Foam into each 38 gal saddle tank) How bad can it be to run off the saddle tanks to see if the fuel is ok? Is there any way to test it? I do not have access to the tanks to pull senders and a sample. If it is bad and I have to change back to main tank, will I need to drain the bowl, fuel lines back to selector, fuel filters, change plugs??? I just want to be prepared incase she dies on the old fuel and I need to get her up and running without a trip to land. Thanks as always guys, Brian."
