backfires under load mercruiser 3.0
Mike Spijkerman
hi new to this forum but i have a problem. my 3.0 merc backfires under load, in neutral it runs fine but higher then 1200 rpm it backfires and runs terrible. I changed the plugs, sets the timing, new fuel filter, new cable between the ign and the coil. but no getting better.
Please help, I don't now what else to do
Mike from the Netherlands Bayliner 175 br 2005 3.0 mercr.
Back fire through the carb can also be a worn cam lobe. Pull the valve cover mark the push rods with a marker. Spin the engine over with coil wire removed if the push rod dont spin you've got a worn lob.
