I've got a 1979 85HP Evinrude that I completely re-built over the winter (Bored .030 0ver, Rings, Pistons,Bearings Carb kits etc... etc.... I've timed it using "Joe Reeves" procedure and everything seems to be right; I don't have a test wheel so I cannot time it under load. I've done the syncronization procedure per the repair manual specs. This thing will start up with a little more than just a "Tap" of the key. I mean it starts right up... However I'm getting an intermittent "Backfire" at Idle. It'll be idling along fine and the out of the blue POW! through the exhaust (sometimes it'll keep running after the backfire, and sometimes it'll kill it). I was just wondering if anyone here could tell me where to start? Should I replace the Coils or Power packs or do you think it's a timing problem or maybe carbs? Any help would be greatly appreciated. I read somewhere that maybe it's a coil leaking through the insulation, or possibly a plug wire grounding out. Does that sound like that could be the problem? If so how do you isolate which coil or wire? Again... any help would be greatly appreciated. Thanks...
