Indecentspeeds
Need some assistance on what to try next; hadn’t used the boat in about 6 weeks, it fired up no problem at the ramp but was idling just a touch off, I didn’t think much of it, figured it was just a cold start. Pulled away no problems, ran smoother at 1500 rpm, but it wouldn’t rev past 4000 RPM, felt like a fuel problem, if I bumped the choke while running it woke up and ran normal for a second. With the silencer off I can see a visible back fire through top carb when the throttle blades close. Video included.
Details:
1999 Johnson 70hp
17’ Flats Boat (650lbs loaded with 12 gal fuel)
Boat gets used about once a month
Rec 90 with Stabil additive
Compression checks out 140-142-150
Replaced fuel filter
New spark plugs
Checked timing and it is dead on
Strong spark on each cylinder
Swapped coil one and two the issues did not move
I always purchase OEM parts
Is this a clear sign it’s time for a carb rebuild?
Should a test anything else before I proceed to look for someone to rebuild the carbs? I don’t care to do this myself as I have re-built carbs in the past and can never get them tuned and sync’d correctly.
I live in South Florida but have always done all my own work, I don’t have a 2 stroke mechanic I trust. I have been running this motor for about 10 years with no issues, besides some minor fuel lines, filters, and regular maintenance I haven’t had to do anything crazy to this engine.
If the issue is the carbs is there anything else I should do for added performance, security, etc….? I didnt want to switch to a 4 stroke until this motor becomes a reliability issue, I’m hoping this isnt the start!
Looking for insight and feedback on troubleshooting and any local recommendations for a good, honest mechanic with 2 stroke experience.
Video of issue:
Thank you in advance!
Details:
1999 Johnson 70hp
New spark plugs
Video of issue:
