B
Brian Thomas
Guest
"I went to winterize my boat o
"I went to winterize my boat over the holidays and found that the motor wouldn't turn over. I figured the battery would be going sometime anyway, so I bought a new one thinking that would do the trick. Still nothing. I checked the new battery with a volt meter and it read right at 12 volts. I hooked the accessory leads to the battery and they all work fine (lights, depth finder, etc.).
The motor turned over and ran fine when I last used it this summer, so I'm thinking this is probably an easy fix but I'm not sure where to start. Oh yeah, the power tilt doesn't work either, so that tells me no power is getting to the motor. So I'm thinking it's either bad battery cables, bad ignition switch in the control box, or a blown fuse somewhere. Or maybe it's something I'm not thinking of. I appreciate any advice on what to check and the best order to check things in to isolate the problem.
Thanks"
Thanks"
