gone_postal
"My boat is equipped w/ Faria
"My boat is equipped w/ Faria gauges and the tach has the warning lights built-in. My current tach registers idle speed to an extent, but never goes over 1500RPM - it jumps when revved, drops when back to idle, but never seems to exceed 1500, so I assume my signal & wiring are good and the tach is bad.
I bought an identical gauge from a surplus store on Ebay - brand new - '96+ Johnson it was stated. They are identical w/ the exception of the last two numbers in the model number, but I assume it's a different revision, manufacture date, etc. The new tach's warning lights turn on during system check when I first turn the key and it beeps, but the needle never moves. It is in the exact same spot it is in in the auction's picture. It's an idiotproof install (i think) - the 8pin wiring harness and setting the selector dial to 6 for my particular motor (only other option is 5).
Any ideas? Defective tach? Is there some sort of safety lock on the mechanism somewhere to keep it from moving during shipping?"
