T
Tony Malburg
Guest
"On a recent outing, my '9
"On a recent outing, my '95 Force 70 killed while out on the lake. The motor cranked just fine but it would not fire. I pulled the cowling to check for anything obvious (i.e. - loose wires, blown fuses, gas flow, etc.) but found nothing to be noticeably wrong. Tried to start the motor again an voila - took right off. Encountered the problem multiple times during that outing - time and tweaking did the trick to get the motor to fire.
Once at the dock, had a buddy assist w/troubleshooting. The symptom almost seemed like the kill switch was in the STOP position. So, while I cranked the motor, my buddy toggled the kill switch from STOP to RUN a couple of times and the motor fired. We thought we may have an intermittent problem with the kill switch so we attempted to bypass it to confirm. In the process we discovered that the switch operates in an OPEN state and that bypassing the swtich did not solve the problem.
The only thing that seems to work when I can't get the engine to fire is to toggle the kill switch a couple of times while turning the key.
Has anyone ever experienced this phenomenon? I don't have a wiring diagram and would like to know how the kill switch fits in to the engine starting process.
For now I seem to have a work around but would like to restore to normal operation. Any insight would be greatly appreciated."
