b94 Mariner 99 problem
pat_wimb
"I just purchased this motor a
"I just purchased this motor and got it on the water today. It started right up with no problem, but once I throttled up it began to sputter and then die. It would go pretty well at low speeds, but whenever I got going very fast it would stall. After a while it began stalling even at low speeds. Does this sound like a carb issue? I know the motor needs a carb cleaning, but I got a little worried that I might have purchased a motor with more problems than just needing a clean.
Also, are there any online resources for the carb clean on this engine? I have tweaked my jeep carb before but this is my first boat motor.
Thanks.
Thanks."
"better safe than sorry, remov
"better safe than sorry, remove and clean carb, install new water pump(every 2 years) before running again. squeeze fuel bulb to see if its a fuel supply problem while runing bad. Lack of gas means lack of OIL
buy a factory manual, worth the money"
