tshelton99
"I recently purchase a '90
"I recently purchase a '90 Bayliner Capri with a 90 Hp Force. The seller said the engine ran good the last time in use a couple years ago. however
would be in need of a Tune up, the engine would turn over with no problems,but would not start up
and run, so he said probly bad wire connection at the Lanny I could not get any spark from any one of the plug wires,even though I had No compression tester with me I pulled the plugs and did the Ol-finger over the Hole test and it seem
OK at the time. I begain to talk to him more about a negotionable price as the boat is!
so anyway with these things known we begain to barter until we agree upon a price, I thought I had done well? just figured it needed a bit tinkering! got it home done a real compression test and found cyl. 1-120psi 2- 115psi 3-40psi
I figured a stuck ring! next put some lub in the cyl let set for a while tried turning it over and
re-checked compression. No change, pulled the
head and found a badly gouged cyl wall 0n #-3 >>
OK now for my Question? can these Cyl take .040
bore? if not can they be re-sleeved? I have read
that some of the Force engines cannot be re-sleeved.. anyone know this to be true fact?
and Last Question>> I still can't get this thing to show any spark ! I by-pass the lanny thatsnot the trouble, I pulled the fly wheel and sanded
any rust from the stat. so? what is thae cahnce of the CDI unti being bad, I've called this Guy up and pretty much Unloaded on him with him being every kind of lyer there are, but he still insist
that it ran with him a couple years ago, but it did skip some and he thought it was in need of a tune up. yeah right!
Thanks for any help or sugestions>>>"
