b89 rude 200hp charging system is cutting upagain
krt
My volt-meter begins to read
My volt-meter begins to read higher & higher the more I rpms I run. It will go to almost 18 volts and close to the red on the meter.It seems that the boat is sluggish to plane when the voltage increases as well. could these problems be inter-related somehow?
" Do you have wing nuts on you
" Do you have wing nuts on your battery??Perko cheesie red battery switch??Either WILL kill your voltage regulator/rectifier causing a FIRE destroying ALL ignition and charging system components!I see a lot of slipped needles on voltmeters,recheck voltage with your VOM.Do you smell anything burnt on the rear of the powerhead? "
