b87 JOHNSON25 hp killswitch problem
4bratsdad
"just got this thing, wouldnt
"just got this thing, wouldnt die,pulled clip nothing, adjusted dial on end of tiller, nothing,any suggestions? also is pull lever on front a choke?,prev owner said it was a primer& to pull it in& out few times to start,is this correct? seems like a choke, when motor is running/cooling should water exit the back in a stream or spray like a shower? other motors i've owned had a stream. shaft was very hot, and water exiting i'm worried i got took, any help would b great thank you"
"thanks 4 the help guys,its in
"thanks 4 the help guys,its in the shop water pump, fried wiring harness that had been rigged, short in stick kill, cracked plunger,that had been rigged, i learned a lesson, trust nobody you dont know, and half that you do!!"
"Harvey,
Sorry you did not ge
"Harvey,
Sorry you did not get any responses...
Considering all that was wrong with the motor that you list in your second post, it would have been a miracle if anyone here could have helped you.
Don't give up on this site...."
