"Hello, I recently purchased a
"Hello, I recently purchased a boat with this motor and the person I bought from claimed that he thinks the stator or trigger is going bad. The engine appears to 'miss' through out the RPM cycle and takes a 10-20min fast idle to allow it to hold idle (barely). Im a computer engineer, no prior outboard mechanic skills but I did come across a site explaining how to run a stator and trigger test and I did. For my model/hp/year motor the acceptable ohms resistance range is 5800-7000, and while my Blue/White reading was 6430, my Blue wire reading was 4180. Would a resistance of 1620 OFF of the low end resistance range be significant to cause the issues I stated above? The trigger and coil tests revealed readings within acceptable range.
mako"
mako"
