"> Boats !
I am not su
"> Boats !
I am not sure if my motor is charging the batteries. When the motor is off and the key is switched to the first position - the voltage gauge says 12.8 'ish. When I start the motor the voltage gauge does not increase at any RPM.
This season, I replaced my batteries w/ a pair of Titan's. The rectifier is new as of last season ( and I recall after this R/R last season that the battery gauge read 14 volts when I was running ).
I own a good voltmeter. Can you describe:
How I can test to see if I am charging ?
How I can test to find out where the problem is ?
Thank you very much.
Sincerely,
Alan"
I am not su
"> Boats !
Sincerely,
Alan"
