"I am having a cranking proble
"I am having a cranking problem. I have a rebuilt starter and solenoid that has cranked the engine beore. When I jump between the battery post on the solenoid to the (yellow-red wire) post on the solenoid the engine will crank. The ignition switch is new and test good. I have tested the shift interrupter switch and it test good. I have tested all circuits all the way from the ignition to the starter slave solenoid and all test good. I have tested all circuits from the starter solenoid to the slave solenoid (yellow red wire)and they test good. At the starter slave solenoid if I jump from the yellow red post to the other yellow red post and then hit the key it will crank. Does this imply the starter slave solenoid is bad? That is my conclusion but I would like some sage advice, electrical is still a mystery to me."
