b81 OMC Sterndrive Upper Gear Case
bowman
I have an '81 OMC Sterndri
I have an '81 OMC Sterndrive Upper Gear Case that I am need to replace. I need to know which years are interchangable. I am having diffuclty finding parts at a reasonable price. Any suggestions on finding parts would be greatly appreciated.
"welcome
by "case", d
"welcome
by "case", do you mean just the housing? Or are you seeking a complete upper?
If the latter, you will need the following 2 bits of info to do any searching:
1. gear ratio (teeth driving/teeth driven)
2. engine model and HP
it's not just a "year" thing for interchange.
what's your budget?
might be cheaper to fix what you have.
Engine Model# 200SPHRCIS HP 2
Engine Model# 200SPHRCIS HP 200 and gear ratio as per repair manual upper 21.17 lower 14.26 total 6.7 and overall 1.49
"We are really hoping just to
"We are really hoping just to "bolt on and go" - so we are looking for a complete upper. As for budget, we are hoping to find something under $1000. So far current estimates are $1200-$1500"
"Have a look at these two char
"Have a look at these two charts - all of the years/HP's that use the 21:17 are listed. It was one of the most popular gear sets.
They would all be bolt and go whether from a 4 cylinder or V8 the uppers interchange as long as it has 21:17. You would have to shim the exhaust housing cover anytime you swap uppers, but that is pretty simple.
http://www.sterndrive.info/id221.html
http://www.sterndrive.info/1982_gear_ratio.html"
If you find one with a 21:16 o
If you find one with a 21:16 or 21:18 gear set you could probably make it work if you changed propellers...depends what prop you have now.
