P
Peter Cronin
Guest
" Two problems.
When first st
" Two problems.
When first started, my electric-start 35 hp sort of backfires (it kicks, almost stopping, then picks up to fast idle again) numerous times before it finally settles into a fast idle.
The colder it is (ambient temp) the worse this seems to be.
Is my choke sticking, or something? Or is this normal and nothing to worry about?
Second: The other day everything ran smoothly, docked the boat, then when it was time to go, nothing, nada, from the ignition switch. I couldn't hear the choke solenoid click, the motor wouldn't turn over; a quick check with the test light on the back of the switch showed no juice, but the battery was fine.
I then took off the engine cover, and used the starting rope to spin the engine. With the key turned on, the engine started immediately. It has since been started numerous times with the key, no problem.
Is this a problem with the ignition lock-out? (I don't even know what this is or how it works, but was told by a handy buddy that there is a lock-out somehow associated with the position of the flywheel, or something). This information was the limit to his handiness.
I just need to know if this incident is an indicator of a problem 1) I may be capable of dealing with, and; 2) that I should do something about before something blows up or we're stranded up that proverbial creek.
As always, thanks for your help. "
When first st
" Two problems.
