boatn_new_b
"Engine was stored in the down
"Engine was stored in the down position for the winter. Engine tilted up fine, but was going to install transom saver and no tilt down. Will lower back down by using the manual release valve and is not binding. However, when I push the down button, I can hear the motor running. When it runs in the down position the motor doesn't sound "right". The motor sounds like the voltage is low but the battery was charged. Maybe something like the pump deadheading due to a stuck valve? When tilting up, the motor comes right up and the motor sounds like it should. Didn't get too much of a chance to check it out yesterday because it decided to rain. Just itchin' to get back on the lake. Thanks, Jonathan Taylor"
