M
Michael Weller
Guest
" How does it work? I know th
" How does it work? I know the water pump pushes water throught the heads, but how? Which direction is water flowing through the two hoses connected to the thermostat housing and the exhaust ports on the heads? Does water come from the pump through the thermostat housing into the heads and then out the pee hole? Why are there 4 holes in the thermostat housing?
I question b/c my motor isn't peeing correctly. A couple of you got me through replacing the impeller, but still no luck. I thought the thermostats might be stuck, but they have already been removed. W/ the thermo housing removed, I put the hose up to the pee hole to see if I could see where water comes out, Not knowing if to expect to see it come from the exhaust ports or the therm. housing, but I never saw any water at all. Is there a blockage somewhere? Why isn't this motor peeing correctly? Please help...I can't find a mechanic who will work on a '79 (too old they say).
??????????????????confused!!!!!!!!!!!!!!!!! "
