"I have a 1979 Evinrude 140.
"I have a 1979 Evinrude 140. The engine was rebuilt 2 years ago and it runs like a top. Compression, spark, and fuel delivery all check out just fine. The problem is this engine has been a BEAST on cold starts start from day one. My cold-starting procedure is to pump the primer bulb, move the warm-up lever to about 3/4 throttle, turn the key for 2 seconds and then press in for choke. Nearly every time the motor will kick over then die. I will repeat this sequence two or three times and then the motor finally fires and runs without dying. Then, as motor warms up and increases RPM I back the lever down until the engine maintains about 3000RPM for a minute or two. Once I've done this the engine will run without any problems.
When the engine is warm I can just turn the key and fires no problem, but the cold starts seem to require a little luck, crossing the fingers, and waving a dead chicken over the engine while reciting a spell
This summer I ditched the choke butterflies on my waverunner and installed a primer system. WOW, what a difference. On a cold start I give the primer a few shots, hit the start button, and BAMMO she's ready to roll.
I'd love this ease of starting on the old Evinrude 140. The wife-unit gets frustrated trying to start the boat and she really dislikes driving it for that very reason. This summer she told me "I'd love to have a boat that you can just turn the key and it starts".
So, now my quest begins to make this old Evinrude easier to start. What would it take to convert this beast from a choke butterfly to a primer solenoid system? Are there certain years of motors from which I could salvage a primer system?
Thanks,
KJ"
Thanks,
KJ"
