randes2000
"Afte running fine for several
"Afte running fine for several hours, my engine died while idling. No spark to any plug. Next day troubleshooting shows: Battery fully charged and engine cranks good. Sensor coil resistance readings are 11.5 and 10.8 ohms. Charge coil resistance is 685 ohms. Charge coil voltage while disconnected from power pack and cranking is 165 VAC. Ignition switch tests OK, not grounding when on. I do not have the neon tester to test the power pack. What other test can I do? Do any of these readings look bad or should I go ahead and replace the power pack?"
