Doug Follett
My local outboard shop had a good lower unit for my B75. Turned out mine was cracked. A couple of questions....
1. I went gently on the removal of the bottom four bolt removal but I still twisted the head off of one of them. It was the one that has the shoulder. Same size head but after it goes through the case it becomes larger in diameter. Is this a one of a kind bolt? I don't see it in the parts fiche. I have a good chunk of it exposed now. Should I just put some vice grips on it and a little PB Blaster and twist it out?
2. The lower section doesn't want to come all of the way out. I removed the cotter pin from the shift lever and it has moved passed that but about four inches further out it hangs up again and doesn't want to come any further. Should I just yank on it or is there something else I need to tend to? I have tried some gentle encouragement but so far it seems caught on something
3. The lower unit was cracked right where it meets the section above it and was leaking water. The section just above is also cracked but only about a half inch and it's not very bad. Can I JB weld this or do I need to replace the whole section? I'm hoping the new lower unit I am picking up next week has both sections or that they will sell me the other part as well.
I hate working on old rusty motors.
