"I've been reading as much
"I've been reading as much as I can and am overloaded.
I'll try to explain this in as much detail as I can... hopefully one of you guys can help.
When I first got this boat (2 months ago), it ran pretty good - 25mph. It has gradually lost power - I'm lucky to get 10mph when the lake is calm. With the throttle cracked full open at the carb, I can only get 2500rpm in gear.
In neutral it'll rev fine.
I used carb cleaner and washed a ton of junk down - ended up rebuilding the carb last week. Had a cracked distributor cap and just replaced it. Installed new plugs - tonight, I will be installing new points/condensor and new plug wires.
I checked the compression last night, but forgot to warm the engine up first. Compression on all cylinders was 100-105psi. I put a teaspoon of oil in each cylinder, and rechecked compression - no difference.
I'm planning on trying the leak down test tonight - can someone explain exactly how to do this and what I should be looking for? I know I blow compressed air into each cylinder and then listen for leaks. Do I need to loosen the rocker arms and check both exhaust and intake valves?
Does anyone have any idea what these symptoms sound like?
Thanks for any help.
Glen"
Glen"
