b70 Johnson 60HP coil resistance value
sashko12
Does anyone know what the resi
Does anyone know what the resistance value should be across the coil for my motor?
And across what points do I measure it?
Thanks in advance.
"---i would say,..that ign coi
"---i would say,..that ign coil,is the least,..of ur problems,..what is ur prob,..no fire,..inter fire??unless that coil/or wire is bad,..ur prob,is under the flywheel...in central tx,most lg boat shops,wont even touch an eng,...in the mid/early 80's.."
"The problem is a weak spark.
I measured the coil resistances yesterday, here what I got:
Primary: insignificant resistance ~1 Ohm.
Secondary: 1.8KOhms = 1800 Ohms
I read in some online document that most outboards should be in 3KOhm - 15KOhm range.
Can someone tell me the spec for my motor please, please?
My_Coil
