"I have a 1969 Evinrude 55 wit
"I have a 1969 Evinrude 55 with push button electric shift. It starts in gear, will shift into reverse and then back to forward but will not shift into neutral (when the button is in neutral the motor is in forward). I have changed the lower unit oil with the Premium oil that it is supposed to have but it had Type C oil in it previously when it stopped shifting to neutral. It also had some water mixed in so I know that I also have a leak somewhere. Any ideas about a cheap easy fix. It worked OK and when it acted up like this I asked around locally and was told to try changing the oil first. I did and then took it out yesterday and still no neutral.
The boat is a 1969 Crestliner 14' aluminum runabout and I am considering chopping it into a plain fishing boat with a casting platform up front and replacing the motor with something smaller if it can't be fairly easily and inexpensively fixed. Any ideas?
Mike"
Mike"
