b67 Merc 110 98hp
planomark
"I have one. It was my Father
"I have one. It was my Fathers and has many hours behind it, some of which were rough while in a family members possession. It faces some potentially pricey repairs, including a prop shaft with enough warp that it breaks the seal on the lower unit and water gets in. I know parts are becoming harder to acquire. I know a man who may still have a same year model unit (I saw it in his garage about 4 years ago) and it appeared to be in excellent condition. But, that was based on outside appearance and I did not pull to cowl or do a compression check, etc. I did note that even the rubber seals around the pull cord we in unblemished condition. I asked him about the motor at that time and he said he hoped his son would take an interest but did not, so it had not been operated since the early-mid 90's. I have moved from the city where it is and it is not practical for me to drop-in to take a closer look, but I am considering a call to see if he still has it and making an offer.
A year ago I made a visit to the Little Red River in Arkansas and rented a boat with a much newer model 15 horse Merc, and I cannot say the 15 horse has that much more (if any) output than an old 9.8 in good running condition.
Beyond replacing cracked fuel lines, cleaning the carb, tune-up and impeller work, what else might need to be done or should I be concerned about on the unit I am considering from this other man?
I am fortunate to have a parts catalogue for the 9.8 so I have a source for obtaining proper parts identification. I appreciate any comments and advice.
Mark"
Those old 9.8s are fine runnin
Those old 9.8s are fine running motors if taken care of. I use to have one. Definately do the compression check and change the oil in the L/U. Sounds like the rest of your plans are right on track. Good luck with it.
"Thanks, IBNFISHN, for the enc
"Thanks, IBNFISHN, for the encouragement. I've had a setback on my aspirations as I learned (today) that the motor I saw in that man's garage is no longer available. So, I have to re-evaluate. There is a '77 unit and a '64 that are puported to be in running condition, but I don't know if many parts will swap out from my '67. I did stumble across one that looks compatible (by the pictures) but it will cost a bit to have it shipped from Cali to TX and there is no telling what condition it is truly in. One thing I've learned in my life... If I try to force something to go a certain way, it always craps out. I guess I need to hold my cards for now."
