b6633hrpwEvinrudecanbt get high speed
tim
" Have a 33hpw. Evinrude that
" Have a 33hpw. Evinrude that runs great except can't get it past 10mph. Have the 3:1 oil and new gas, new prop put on and now this problem. Anyone have an idea of why it won't kick into a higher speed?Boat seems to have a wider wake when new prop on. "
"Tim...Hopefully you meant to
"Tim...Hopefully you meant to say 50/1 pertaining to the oil (1 pint oil to 6 gal fuel).
If you have compression and ignition, and the throttle butterfy is opening completely at full throttle, I would suspect that the carburetor is fouled somewhat. If so, it will require cleaning & rebuilding.
Joe
