b53 3hp light twintelltale stream or not
kevmc
"Just inherited a '53 3hp,
"Just inherited a '53 3hp, runs good but no water pressure telltale. Don't see a place for one....??
How do you know if pump is working..??"
No tell tale...a fine water mi
No tell tale...a fine water mist should be visible from the exhaust slot when the motor is running
Not much coming out.
How much
How much of a gap is OK between driveshaft and waterpump housing? I've heard that it might suck air thru this gap if housing is worn in excess.
