b02 DF90 Lower unit wonbt drop
badnole
"Hello,
I have the DF90/115/
"Hello,
I have the DF90/115/140 Four Stroke service manual. It says to "Remove (7) bolts". 6 bolts 3 on each side under the fin I removed but it calls for a 7th seperate bolt from the driveshaft housing which I can not find as shown on the picture in the service manual. Do I have to pry it apart? I thought it would drop from it's own weight.
Please Help.
Steve"
I believe there is a rubber ca
I believe there is a rubber cap on the top that allows you to remove your anode. Once the anode is removed look up in the hole. There is another bolt in there.
Pat
Thanks Patrick. I solved the
Thanks Patrick. I solved the problem by looking closer. There is another bolt under the trim tab which I removed and the lower unit came free.
I have another problem which I will start another thread with.
