asembly the alpha one to the motor
Rulo
I change the shift cable bellow and I need engage the alpha one gen II drive system to the motor, my question is, if I need to disarm the yoke assy.
I need to mount the drive system to the motor. I can't conect the shaft, it is very dificult, please send me some tips to assemble.
You need to check engine alignment w/an alignment tool. If that is correct then the OD shaft will slide into place.
the reason I ask is because of the terminoligy you are using.once alignment is correct you can rest the drive on some wood to have the inputshaft as close to the height of the gimbal bearing.with control box in full foward gear, slide the driveshaft into housing making sure the lower shoe(the part bent at 90 degrees)
goes into the upper slot. both of these will be facing the same direction,in a straight line. push drive on and tighten the mounting bolts.
Will also send with translation.let me know if it works.
la razón le pido es el terminoligy son using.once alineación es correcta usted puede descansar la unidad en algo de madera para que la inputshaft a la altura de la caja de control de bearing.with de cardán en marcha completamente hacia adelante, deslice el eje en el bastidor asegurándose de que la zapata inferior (la parte doblada a 90 grados)
entra en la ranura superior. ambos se enfrentarán el mismo sentido, en una línea recta. Empuje la unidad y apriete los pernos de montaje.
También se enviará con translation.let saber si funciona.
