Article: Outboard Motor Water Pump Impeller Replacement Guide
I have a 1972 evinrude 9.5. Got the lower unit off and replaced the water pump but now when I put it back together my I lose forward gear. If I don't tighten down the lower unit the gears work.
Did you take one bolt out of the coupler when you took it apart ???------------When you put it back together did you line up the notch in the shift rod with the hole in the coupler before you put the bolt in ??
This 5.5HP Petrol Water Pump at crazy sales is multipurpose powerful pump is ideal for all of the home needs. Make use of it to pump water using a flooded cellar, irrigate the garden, fight fires or possibly for durable cleaning.
Featuring 50mm inlet/outlets, accompanied by a flow of 30sqm hourly and coordinated with a robust 163cc 4-stroke engine, this is the perfect water pump for creating sure small problems don't turn in large ones.
