L
Luc Vinet
Guest
" I was tuning my 15R74S and f
" I was tuning my 15R74S and found out the armature plate that turns with the trottle is a litte wabbly. Is it normal to have a little play or should it be tight? If it should be tight, is there a way to solve that problem?? What should be the torque of the flywheel nut??
With that engine does anyone now what is the correct pitch i should be using when i put it on a 14 1/2 X 70 inches wide fiber glass boat witch is 400 pounds. "
