Great! Things are looking up.
I am pretty sure I am going to need all 3 timing belt gears/pulleys and I may need a block. Oh the starter solenoid is missing also.
The motor had been rebuilt and had less than 100 hrs on it when they decided to replace the floor. But after that got done it sat for almost 3 yrs and the #4 cyl accumulated a bunch of water causing what may be catastrophic galling. Funny thing is, if it wouldn't have been rebuilt the water would have passed right by the rings and the damage would have been much less.
This is my 1st boat and it may end up as a labor of love but I am severely limited as to the amount of money I can put in it because of my disability. So if anyone has any fantastic cost saving ideas I am all ears.
Hi Chris,
Where to start? First off, who "rebuilt the motor"? Been down that road before. Sometimes the "rebuild" is a set of rings and maybe some bearings, nothing done properly, just enough to get it going. If it was a complete, professional rebuild you could try pulling #4 piston and see what you find. If everything else is good inside it's possible you could get by with cleaning it up with a hone and new rings--perhaps a new piston. That's one path.
Another thing to consider is you can get a good used B21 car motor from a wrecking yard or maybe a rebuilt short block. That's another path. The motor/block is essentially the same, pulleys, etc.. The cam is different however--bu that could be swapped out along with the "marine-ized stuff" heat exchanger, water pumps, etc.. . So that's another path you could consider.
IF funds are limited, you might think long and hard an maybe even cut your loses. After the motor, you may have hull problems, perhaps a rotting transom or stringers (all hidden from view). If you have to rebuild your boat from the inside out, that is a LOT of work and money. Just consider it.
How is the sterndrive? How are the bearings and seals and U-joints, bellows, hose fittings, etc. etc. etc...
Sometimes the wiser move is to part the boat out and buy one that's running and take it for a long test drive and maybe have a marine mech look it over for you. Hard to say without taking a long hard look at it in person.
Just some quick suggestions here. Others can fill in the gaps. I think most of us have been where you are.
The learning never stops!
