RicardoMarine
Gold Medal Contributor
this is a repeat of my post #11
So I wanted to attach some pics of what I did. I took all 5 plugs out which are not in this pic (too hard to take pics of those. I let them all drain thoroughly.
Make sure that you probe these drain ports to ensure that all water will drain out.
I took off the 4 hoses shown in the pic. let those drain (although there was not much to drain after the plugs. I poured AF into each of the 4 hoses. Mostly 1/4-1/2 gallon per hose. I did notice AF coming out the back once filled on 3 of the 4 hoses.
The one hose did not seem to empty out the back like the others did. I must have poured over half a gallon in this one. so I called it good there. This hose was the bottom left (bigger) hose.
This larger hose would connectd to the Stbd side of Circulating pump.... correct?
If so.... that would be the Circ Pump suction hose.
This plug will allow water to drain from the Circ Pump.
From my description and pics can you tell if I am missing anything?
Again....... adding AF is unnecessary..... it simply gives some of us that "Feel Good Feeling".
If Hell Bent on doing this.... just make certain that there is no residual water that could possibly dilute the AF.
Better yet..... drain it again afterwards.
Just plain ole air will not freeze expand and crack our expensive cast iron components.
I also sprayed fogging oil into carb till engine stopped. This was done before all of the above.
Two points:
1...... Fogging a carbureted V engine requires us to spray an equal amount of fogging solution into each primary throttle bore.
Reason.... these engines use a dual plane intake manifold. Each plane delivers fuel/air to 3 cylinders (V-6 engines) 4 cylinders (V-8 engines).
If we miss one plane, we also miss 3 or 4 cylinders.
2..... It's best if we do not allow the fogging solution to kill the engine.
Instead, have a second person hold 1,200 rpm while you introduce the fogging oil.
Have that person continue to hold the 1,200 rpm throttle position and cut the ignition while you continue spraying the fogging oil until the engine comes to rest.
This ensusres that the fogging oil did not undergo combustion.
Proper fogging can take place within 10 seconds or so.
