Are all VP 280 drives interchangable
43_lx_merc_1996
"Are all VP 280 drives interch
"Are all VP 280 drives interchangable? For example, is the drive for a 4cyl the same as for a 350? What are the differences?
Much appreciated."
"So, just to clarify, all gear
"So, just to clarify, all gears for both V6 & V8 angines are 1.61:1? Are there any other diferences?
Thanks again for your input!"
"There are quite a few variati
"There are quite a few variations. The clamping ring in the upper gear assembly may be for the 1/2" bolt, or for the 18 mm (or 3/4" fine, I don't remember) or for the two-screw pivot pin. Also, the intermediate housing and transom shield are different for the outdrive with power trim. There are also some versions that carry duoprop."
"So when I'm shopping for
"So when I'm shopping for a new 280, I'll stick to the ones compatible with a V6 or V8. Thanks again. See new post re: gears grinding in leg."
