My boat is a 1972 but there were obvious upgrades done before I bought her. She originally had a Chrysler Super Bee, but the boat came to me with a VP 260A (SBC). Her outdrive is what appears to be a 250. When I bought her I was worried about the outdrive so I bought a running 250 as a spare ($80), but it was for a 4 cyl, not the 8 cyl that I have in the boat.
Well, then I knocked off the anti-ventilation plates on both sides of the outdrive while backing the boat into the boat-port in the back yard. I was thinking that getting the parts welded back on at a machine shop would be at least a hundred bucks so I bought a complete running 280 for a V8 for $100 thinking I'd just use the bottom section...which I assumed I could install on my 250 unit with the proper bearing shim procedure.
In the meantime, I glassed the broken parts back on to the old Aquamatic 250 and because we seldom go above displacement speeds (8mph) I'm convinced we'll be ok.
So now the question.
The 280 is in relatively good condition...clean oil, smooth U joints, no missing parts - everything functional. First off, is it really a 280?
Second - would there be any advantage to using the 280 instead of the 250?
And lastly - what complications could I expect, if any, in case I do replace the 250 with the complete 280?
