I have a 1986 Sun Runner 310SB cruiser which weighs in at 9,960lbs. It has a waterline length of approximately 28ft and a beam of 11ft 6in.
Original power units(2) are Volvo Penta AQ260/290A I have rebuilt as new original AQ290A outdrives on the boat
This boat will be completely re-powered this year with remanufactured early version(1985) Chevy small blocks from Advanced Engine.
My question is what diameter and pitch props would work best for the boat. When I got the boat, it had 2 15 x 19 aluminum props on it. Because of their condition and the fact that the boat would not get on plane, RPMs would only get up to 3000, I put 15 X 17s on it. It still ran like crap even after going through everything you guys recommended. We replaced the Starboard engine last August, and the boat was running great. got on plane and cruising at about 24-25mph WOT. The starboard(new) engine WOT at 4000rpm, the port engine about 3200 to 3400. So I backed the starboard engine down to match the port engine. Coming back one evening, we threw a rod in the port engine. Ok, tired original 1985 engine. So we are pulling the boat in early April to replace the port engine to match it's brother on the Starboard side.
Looking up prop sizes using the calculator, it says I should run a 17.9 X 20 something. First, I dont know if the diameter of anything bigger than 15" will fit and not hit and second, I think the pitch would be too high and cause slippage. I am thinking of just ordering new 15 X 19s for it.
Any input is always appreciated.
regards,
Kevin and Tatyana
aboard the Russian Princess on the Ohio River
regards,
Kevin and Tatyana
