AQAD41A raw water hose size
keverno
Can anyone confirm that the inlet raw water flexible hose that runs from the fitting on the transom plate, in my case on starboard engine to the power steering cooler in then on to the brass pipe that fits into the raw water pump has an inside diameter of 1” (inch)
I am overseas at the Sydney boat and have seen an excellent fresh water flushing system that I wish to purchase but I am not a 100% sure of the ID of the rubber raw water hose to get the correct size system
If you are referring to the bronze shutoff valve on the outdrive drive on the inside of the transom then the line the hose is attached to is flaired to 1 1/4 OD. Therefore the ID of the rubber hose is probably the same or one metric size smaller. You decide.
