Have a weird problem with my injectors. Last week started up my STBD engine which idled normally for a couple of minutes then I heard this "poof" and continuing "poof poof" from the engine bay. On investigation I found that the retaining collar on No 4 injector had broken in half allowing the injector to lift from it's seating and combustion gases to escape around it. These collars are not that substantial so I thought that this collar had just failed due to old age. Anyway I had a new collar fitted to the injector and refitted the injector with new washers. I noticed that when removing some rags around the fuel lines I heard a sound like some small metalic object falling into the bildge. Couldn't find what this was so I started the engine. Immediately I had this "poof poof" again this time coming from No 1 injector. Once again the retaining collar was broken, and half of it was missing. I eventually found the other half in the bildge and conclude that this would have been the noise I heard when removing the rags. So it would seem that both No 1 and No 4 injector collars have more or less failed at the same time and one must assume that it is something common to both of them like excessive pressure in the combustion chamber or some other cause. I have checked the cooling water and although the water level is down a bit there does not seem to be any evidence of oil in it nor does there seem to be water in the oil. Has anyone experienced this sort of problem before or might have any suggestion as to the cause?
