joe_merchant
Before putting the gearbox back on the outdrive, decided to check the clearance between the split ring spacer and the top nut on the gearbox. The manual calls for clearance of 0.004-0.020". Mine is at 0.013".
Wondering if I should go ahead and replace the washer now, even though it's still in spec. I don't want to fall into the "if it ain't broke - fix it until it is" camp but want to be proactive with regard to potential problems. This is a 4 cylinder with a left hand prop and only put on about 50 hours per year.
Is it something I should be concerned with now or just button things up, wait for spring, and go boating?
Page from manual is attached below:
View attachment split ring spacer install.pdf
